Old 02-05-2009, 12:05 AM   #15 (permalink)
IT_Guru
There is a video on YouTube of a guy that popped one of these into his Bravada, and then went for a drive videotaping the stock, un-modified MPG meter showing 60.1.
No wonder these sell..... If he REALLY wanted to see what he was REALLY getting, he'd fill up and run serious, documented, controlled usage tests over time and he would TRACK exactly what he was using to refill the tank. Videotape THAT and see if it sells.
Idiots. That and the O2 sensor isn't seeing what it should be (not calibrated or intended for HHO in the lines) and lying outright to the MPG dev.
