Originally Posted by jamesqf
So I'm trying & trying to get a wrench on the A/C tensioner: 17mm's too big, 15mm too small, and I don't think I've ever seen a 16mm. So finally I get out the other set, and guess what? 5/8 fits perfectly.
I'm sure Toyota would describe the bolt in question as having a 16mm head. 5/8" ~= 15.8750mm. The broach on a 5/8" wrench or socket is slightly larger than 5/8" to accommodate mangled bolts heads/nuts.
Larger more complete sets include 16mm, though bolts with that size head are uncommon.
