Old 02-10-2009, 02:20 AM   #15 (permalink)
ConnClark
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
It's not necessarily a problem - power plants (even coal fired ones) generate power more efficiently than gasoline engines, so the net energy use is lower. Also, many people have access to renewable (clean) electricity generation so net pollution is lower too.
Lead acid batteries are about 75 to 85% efficient. ( http://www.sandia.gov/pv/docs/PDF/batpapsteve.pdf )
A 14.4V charger is about 86% efficient. (
stepdown transformer 95% efficient * efficiency due to diode losses = .95 * (1 - (1.4/14.4)) = 86% )
average efficiency of powerplants = 33% Power Plant Efficiency Hasn’t Improved Since 1957 : CleanTechnica
transmission and distribution efficiency = 93.9% http://tinyurl.com/dghtoh
so 100% * .33 * .939 * .86 * .85 = About 23% efficient. Just about the same efficiency as a typical car engine
