Old 02-10-2009, 10:26 AM   #20 (permalink)
ConnClark
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
Nice calculation ConnClark. However, I once calculated efficiency of an engine using EPA mileage for my Matrix and Paseo. It came out to 13% for each. 23% would be a HUGE increase. Ironically, thats about what it came out to be when I plugged in my summer mileage for the Paseo (which wasn't too far from 100% above EPA). There are pretty huge gains to be had for supplimenting or replacing gasoline for electric power.
The 23 % efficiency is for the engine alone. Using mpg you have to account for transmission, drive line, aero, rolling friction, etc...
some more efficiency factoids.....
A typical new car engine is more like about 25 to 28% efficient. A diesel is about 30 to 45%.
A modern supercritical Rankine cycle power plant is about 42% at best. (if your power plant is more than 10 years old don't plan on this being the case)
clean energy ( geothermal, solar, wind, hydro electric, and biomass) made up only 7% of US power sources in 2006 and 90% of that was biomass and hydro electric based.
