Old 02-11-2009, 10:30 AM   #3 (permalink)
spoil9
Converting from AC to DC or DC to AC results in major losses of power which is why it's not that simple to do in a project like this. Plus the components needed to handle that much power and heat would make it not worth the effort.
AC is a much better method of powering a motor (IMO) but your're right, the controllers require more electronics to handle the PWM at that power level so it's more expensive. Plus you would have to add a DC to AC inverter before the controller since there is no way to to store true AC.
