Old 02-11-2009, 01:01 PM   #4 (permalink)
wagonman76
wagonman76's Avatar
Red Car - '89 Chevrolet Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 Pontiac 6000 LE Wagon
90 day: 28.26 mpg (US)
It would be easiest and most surefire to just pull the instrument cluster and tap into it there. If it goes together like most GMs of that era, you will be able to trace the circuit from the back of the speedo/odo to whatever wire the connector plugs into. Whatever wire is dedicated to it is what you want, there should be 2 other wires (12v ign and ground) that go to multiple places on the circuit so you don't want those.
It is most likely dark green. It was dark green on my 92 Trans Sport van.
Also, it will probably turn out to be more like 8000 PPM. No idea why it is, unless the mpguino counts a pulse twice as it energizes and de-energizes. Both my 6000 wagon and Trans Sport van are listed as 4000 PPM in the service manuals, but actually are around 8000 according to the mpguino.
Your microseconds/gallon will probably be around 251500000 as well. Thats what both my 2.8 and 3.1 MPFI engines work out to be on average.
Winter daily driver, parked most days right now
Summer daily driver
