Old 02-12-2009, 12:54 AM   #7 (permalink)
NiHaoMike
Originally Posted by ConnClark View Post
95% or more efficiency is a pipe dream at high current levels and fluctuating loads. In the 11 switchers I have designed the most I got out of them has been 92%. I also had low loss capacitors and low voltage drop diodes and low RDS MOSFETs to work with.
Most of the losses are on the low voltage side. Using Litz wire, oversizing the windings, and using synchronous rectification all help efficiency. Low switching frequencies also reduce switching losses but increase size of parts.
Getting high efficiency at low voltages is a big challenge. Nonetheless, 95% efficiency is certainly possible at low voltages. The PTV08T250W is 95% efficient when outputting 3.3v at 50A from a 12v supply. Getting that kind of efficiency when outputting 14.4v from a 20v+ source should be a piece of cake by comparison.
If America manages to eliminate obesity, we would save as much fuel as if every American were to stop driving for three days every year. To be slender like Tiffany Yep is to be a real hypermiler...
Allie Moore and I have a combined carbon footprint much smaller than that of one average American...
