its a steam engine. the coolant from the engine comes in the and goes out from the bottom right. this heats the solvent which evaporates and powers the drill-pump to make electric. the solvent condenses in the radiator. and the solenoid valve, reservoir and level switch are there to stop vapors from by-passing the drill-pump. the solvent is returned back to the heat exchanger to form a closed loop.
a steam engine powered alternator, from components all readily on ebay.
Nissan Leaf 24kwh. Average FE = 300mpg 3.6miles/kwh (@plug)
