Old 02-17-2009, 12:12 AM   #8 (permalink)
Bicycle Bob
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
Maybe if you poke around a junkyard you can find some helper springs, or something that can be made to fit and has a little bit thicker wire in the coil.
Given that you don't have to worry about hot exhaust parts, you could do a very smooth belly pan, which is better than lowering and reducing underflow. The smooth, sealed front end sounds great, too.
