Old 02-17-2009, 12:22 PM   #18 (permalink)
rmay635703
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Originally Posted by Peter7307 View Post
Gas costs AU$ 0.010658 / Mj with a supply charge of $21.15 and of course tax of 10% an all of that.
Not sure what the "supply" charge means for a piece of pipe in the ground? I don't think there is a lot of maintenance required !
Water costs AU $ 1.0276 / 1 000 litres. and I use around 50/litres per day.
Pete.,
That water rate SUCKS but I believe it is coming to the US as well since we use more water than what physically falls in most areas. Anyway I would strongly recommend you get a composting toilet, they do not stink, they are environmentally friendly, you do need to use different toilet paper (usually) but at that rate I would be taking a lot of sponge baths, smelling like a frenchman, using disposable paper plates and using a composting toilet so I wouldn't have to pay them.
I think everybody pays something similar to a supply charge, though the folks in control might call it something else, like a tax or an access fee or a metering charge.
My folks pay roughly $75 a month to have gas, water and electric hookups and another $20 just to have a phone, this is before they even use ANYTHING!
Add to that if you TRY to conserve power many utilities will charge you a higher rate because you aren't using enough power
There are many hidden costs that go away if you produce your own power.
I wish solar would drop a little more so we could drop this utility BS.
Ah well
