Old 02-17-2009, 07:23 PM   #29 (permalink)
modmonster
Tracy - '00 vauxhall corsa
if my mod reduces cooling efficiency in the radiator or heat exchanger then this will have a negative effect on main engine efficiency. is this right? what is taken as the cold reservoir when doing the thermal efficiency calculation for the ICE?
Nissan Leaf 24kwh. Average FE = 300mpg 3.6miles/kwh (@plug)
