Old 02-17-2009, 07:35 PM   #18 (permalink)
Mazda_2.3
Amateur
Mazda_2.3's Avatar
Ahead of you on the grill. I'm thinkin that the upper grill alone should be adequate to cool the engine compartment. So, I've cut a 1/16" aluminum insert for the lower grill and am halfway to covering it with black vinyl to spruce it up. It's gonna look a little rougher than I anticipated because the grill curves from left to right but also top to bottom making it difficult to get a good fit w/o the appropriate tools. It should work though and if I like what it does to my MPG I may redo it to look better. I should have a picture of it online by Monday.
Oh and good to hear about the Scangage (that it will work with keyoff).
Originally Posted by PaleMelanesian View Post
His is stock. I can see how you could clean up the nose a lot, just by covering the gaping grille. There is NO need for even half that much opening. The shape is good, you could just do some kind of skin over what's already there.
