Old 02-17-2009, 07:57 PM   #31 (permalink)
aerohead
hot water
the hot water could power a turbo-generator as is done in Israel with solar-heated water.Refrigerant,just like in your air conditioner, is flashed to superheat with the hot water,then channeled through a multi-stage turbine,turning an electric generator.A small portion of the produced power is used to compress the gas to a pressure where it will condense back to a liquid,to repeat the cycle.----------------- If both the cooling system and exhaust heat of the engine is harvested,your looking at 2/3rds of the fuel's energy as your input energy.---------------- The electricity produced could do anything you choose.
