Old 02-18-2009, 10:13 PM   #24 (permalink)
Mazda_2.3
Amateur
Mazda_2.3's Avatar
Originally Posted by PaleMelanesian View Post
Notice how the lowest nose has the lowest drag. Based on this, I'd go for a smooth upper block first, then block the lower as needed. Even if the car has a fairly smooth bottom, there's the car-ground interaction to deal with, which is more draggy than the free air above the car.
I can kinda see the image going both ways. Yes, less drag with a lower nose but when that low nose has such a huge opening I could see that benifit being cancelled out. This did give me a great idea though.
http://ecomodder.com/forum/member-ma...ibilities.html
just that small opening between the two and perhaps two parallel openings on the lower grill about 1/2" tall each running the length of it. . . hmm...
