Old 02-18-2009, 11:52 PM   #11 (permalink)
daisy
Originally Posted by TestDrive View Post
I definitely don't follow the part about rise.
I've simply found that it's hard to judge intuitively how much speed will be required to coast to the top of a hill. I've come to realize that this is because the vertical distance is not a function of velocity, but of velocity squared.
Let see how well I'm doing with the rest.
Let's assume the scale of your regular dial speedometer reads 0-110 mph.
Let's also assume that the needle sweep from 0-90 mph is 90*.
What do you want the needle sweep from 0-60 mph to be?
  1. 60*
  2. 40* (my understanding)
  3. Some other number of degrees. (If so, what number?)
If the answer is 40*, I'd don't see why you'd need/want any additional scale markings other than km/h.
Yes, 40 degrees.
The speed markings (both mph and kph) would be on a parabolic scale. They would start out squnched together and spread apart as the speed went up. The rise (in feet/meters) would be a linear scale, just like the current speedometer.
What I think I'm going for is trying to get a better intuitive grasp on how much kinetic energy I have and how much drag I'm experiencing. Maybe it won't do a whit of good, or maybe I'll be surprised.
