Did someone steal your gas, or did you get ripped off at the pump? Or even a small gas leak?
Last 2 tanks of the Celeb for last year were a bit fishy, last tank being the worst. Fuel use always showed 1-8% above the theoretical injector flow rate. Last tank showed 10% LOW. Either I got ripped off at the pump or someone stole my gas. I'm thinking the latter because the gauge dropped faster than it should have, and there were no fuel leaks.
Winter daily driver, parked most days right now
Summer daily driver
