Old 02-22-2009, 09:13 PM   #6 (permalink)
Ryland
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
If your radiator cap can keep the pressure at 14psi then a coolant mix of 50/50 ethylene glycol will boil at 263F, at that point you will rapidly start to loose coolant as the coolant escapes in to the over flow it will boil at 226F, so you will get ALOT of steam and your coolant will be gone.
