That's why I mentioned it - I figured there was SOME problem I'd forget about.
Anyway, we're looking at going with a 12,000 BTU unit over the 18,000. It says the 12k is for 300 to 500 square feet.
We're more concerned with heat than cooling. Would putting that in a space around 550 square feet be over-taxing to the unit? It's job wouldn't be primary heat, but merely to help hold temperature once the furnace has the area up to temp (from overnight low).
