Old 02-25-2009, 10:50 AM   #9 (permalink)
Ferr3t
Young'n
Red Dread - '03 Ford Ranger FX4 Level II
90 day: 19.81 mpg (US)
Bessie - '08 Honda Civic Hybrid
Thanks for the information everyone, and I do have a Tachometer Wagonman, so I'll try to keep an eye on it. I think that I can feel it engage/disengage but trying to keep my eye on the tach, vacuum gauge and the road and be hard sometimes for a newbie.
Originally Posted by RH77 View Post
I have a '98 Integra and understand your question. The Honda 4-speed automatic has 3 lockup positions: partial, half, and full. If you select D3 on the shifter, it will not engage the torque converter -- otherwise, the TC can engage in 3rd or 4th gear in D4.
So how to know? The easiest way to know, is to watch for a small drop in RPM. Full lockup is about a 500 RPM drop, with the other two slightly less.
Lifting the gas pedal and re-applying the throttle will definitely tell you if you're in lockup. If the engine RPM goes up with no drop, it's not engaging. If it slips down a bit -- you're engaging.
Personally, I have a quite the issue with TC engagement. Coolant temp is a big factor. The Honda Transmission Control Unit (TCU) is the "End-All Be-All" in transmission decisions. If you engine-off coast, then it confuses the hill-logic control circuit, and will not engage the TC until the calcs satisfy a condition of higher-speed cruise. It uses engine load, speed, acceleration, deceleration, and throttle position to determine if a your going up or down a hill.
Long story short, gaining access to a shop manual will help tremendously.
Best FE to you...
RH77
I have a Chilton's manual for my vehicle but it lacks alot of information about the j30a1 V6 model that I have, most of the focus is put on the four cylinder models. Thanks for the information, how exactly does your coolant temp affect your lockup? Does it run too hot?
Originally Posted by Christ View Post
Find the wiring that goes to the TC lockup solenoid, and get a wiring diagram.
You can connect a light to the lockup solenoid's switched side, which will light up when the solenoid is active... it's kinda the same thing as a Vtec indicator light, a common thing among people who think Vtec is some ungodly power-adder in Hondas.
"The Vtec just kicked in, y0!"
Thank you also Christ, I'm pretty sure that I have wiring maps in my guide.
