Old 02-09-2008, 11:21 AM   #61 (permalink)
Lazarus
ECO-Evolution
Lazarus's Avatar
Iron Horse (retired) - '97 Iron horse Intrepid
Ninja - '08 Kawasaki 250R
90 day: 76.23 mpg (US)
You might know this but there should be two clicks on the front shifter when you shift which will move the FD either further out or closer in depending on where you are running the rear cogs to keep it from rubbing. When you engage it all the way push the little shifter just enough to bring it back a bit without taking it off the big ring. Also what gears is it rubbing in. You should not be extreme cross chained, Big ring front big cog back or Small ring front small cog rear that will wear the chain and cogs fast and will rub on most road bikes.
"Judge a person by their questions rather than their answers."
