Originally Posted by LibbyMetro
the metros brakes arent like most other cars frank , it has an outer hub , you have to remove it to get to the rotor, i asked a friend tonight and he told me how, theres no set screw , hew said its rusted to a metal sleeve and you need a puller, thanks all for your help
HI
You are at the same point of replacing the brake rotor that I am with my 1992 Geo.
You say that your friend told you how to remove the hub. Could you tell me?
Is the hub nut keyed? Does it have right or left handed threads? I am replacing the left
( passenger side) brake rotor and pads. Also could you possibly know the exact part number? Thank you for your help.
