Originally Posted by dcb
Did you leave in the injector delay?
Yes, I started off with the injector delay at 100uSec based on the oscilloscope graphs of the fuel consumption signal posted by rmccomiskie. I also briefly switched it back to the default setting of 500uSec to see if the MPGuino would generate the same erratic readings noted by rmccomiskie when he used the Audi FC signal. My GPH readings were stable with either delay setting, but I switched back to 100uSec for now.
