Old 03-02-2009, 05:28 PM   #7 (permalink)
MazdaMatt
2k2Prot5 - '02 Mazda Protege5
90 day: 33.82 mpg (US)
I'm interested in the often repeated advantage number one. "AC can be more efficient". Why is this? Is it because the proximity from the winding to the pole is actual a perfect sinusoid? I have read that driving an AC motor with a square wave, or a 6-step is inefficient - isn't a DC motor just the same as an AC motor except that it mechanically transforms the DC signal into a square wave AC? (what's that part called, the commutator or something?)
This Field Oriented Control concept is very interesting. It would be worthwhile to design a controller that has all the inputs required to use FOC, but start with a simple Volts/Hz controller. That paper shows massive advantages to FOC over V/Hz - specifically, it shows "DC motor-like" low-end torque... which is one of the main benefits of a DC motor.
btw, LOVE the motor sound
