Off and on over the last few months I have posted that I was going to design and build my own EV. Well finally things are coming together and I have made some decisions based on practicality.
The vehicle is going to be a 3 wheel design with a minimum speed of 75 mph and a range of 80+ miles (will probably go for 100+....all depends on my budget, the battery pack will be scalable)
I have created a blog charting my efforts and designs and already includes some designs that I am working on in SolidWorks. You may recognize the design because it will be based on the Australian TREV. However I do plan to improve its aerodynamics significantly.
Here is a sample image of what I have so far:
IsoViewFullCarVer2 - Vox
The main information/advice I need right now is regarding the suspension and steering system. I am estimating the total weight including driver to be around 700 pounds at the moment (could be as low as 450 though). Also need to learn about breaking more. I am hoping to not need any hydraulics for braking pressure (hopefully that would be unneeded weight/complexity).
The plan is regenerative breaks from the rear wheel and mechanical brakes of sort on the front. I also need to figure out a way to have the mechanical brakes to only kick after a certain amount of force is applied to the pedal so that the regenerative brakes do almost all braking except during emergencies.
Please check out my blog:
BenW’s blog - Vox
