Ok, so I'm going to say that the solar idea is out. I over-estimated how much power a solar panel can produce and underestimated how much power the car actually uses. I was thinking that this 6'x3' cell I found a Fry's would cover it, but if it won't then that is the largest I can fit on the roof of my car, period. But now I'm thinking of removing the power steering which will remove some load, but the question is, will I see a noticeable improvement, enough to make it worth my time and effort to bother removing it? I have tried driving the car just rolling with no engine and it's pretty easy to turn without power steering so that would be really the only thing I can sacrifice off the engine at that point.
And to what Frank Lee said about the defrost working without A/C. There are some days that the only way I can get the windows to become un-fogged is to run the A/C. It usually happens when it's raining and cold outside so opening the windows to compensate for the temperature difference just isn't feasible so the A/C is my only option.
