Old 03-05-2009, 10:45 PM   #14 (permalink)
jamesqf
Hi James,
There is probably very little connection between what an amplifier is rated at, and what it actually is able put out into a dynamic load (the loudspeaker and it's crossover). Also, there will be losses since no amp Class A/B amp can be very efficient, by definition.
Sure. I was giving a simple ballpark figure for an upper limit on the power draw. Beyond that, I'll leave it to the EE types, except to remark that the amps & other electronics can't be all that inefficient, since the wasted energy would appear as heat.
