Old 03-06-2009, 12:30 AM   #15 (permalink)
Mogal
Metro
Mogal's Avatar
Accent - '09 Hyundia Accent SE
90 day: 31.54 mpg (US)
F-150 2.7 Eco 2017 - '17 Ford F-150 XLT
90 day: 19.53 mpg (US)
Thumbs up
I unplugged the batt for about 2 hrs after work, then started it up again.
The car started on a high idle(almost 2k) and slowly came down to about 1200rpm... as it warmed up...
I went for a spin around the block, and once up to temp, the engine started to cycle again...
Running though my head what was going on, and a way to fix it, I pulled up to a stop light...
still cycling between 1000-1800rpm...
And for whatever reason it 'clicked' went to 1800rpm, then dropped down to idle(850rpm) at that stop light, and so far hasn't done it since.
But one thing I have noticed, is when I glide, the car drops down to about 1100rpm durning the glide, only dropping to 850rpm if the car comes to a full complete stop.
Over the weekend, I'll be making a mount for the tach sitting in the cluster cubby hole(or on the steering column)... I'll post pics when I'm done if anyone is interested.
Thanks once again for the help.
Chris
Shift your Attitude
