Old 03-06-2009, 02:51 AM   #13 (permalink)
Coyote X
nut
Coyote X's Avatar
Metro XFi - '93 Geo Metro XFi Convertible
90 day: 62.17 mpg (US)
DR650SE - '07 Suzuki DR650SE
90 day: 55.26 mpg (US)
Send a message via MSN to Coyote X
120V@100A would require (at 100% conversion efficiency) 12V@1,000A. the formula to remember is P=V*A so Power in Watts = Volts * Amps
You can increase the voltage or amps but the other will drop if you are using the same amount of power from the battery.
