Originally Posted by Ferr3t
Awesome work Jimepting! Although I'm curious as to why you didn't start from the front and work your way back? Regardless...this should help with some of the flow under the car  .
Toyota did some under belly work at the front, immediately behind the front bumper. Though there are a couple of areas which can still be enclosed, the front didn't look nearly as rewarding as the back. I will probably do some additional front work when I get the chance.
The front, around the engine, would seem to have some additional constraints. It would seem that the exhaust system would need to be left open, and some airflow out of the radiator area must be maintained.
Sorry, I don't have pictures of front area. We are traveling in the southwest and my ramps (concrete blocks and boards) are stashed in a weed patch in TN - no not that kind of weed
