So what's the point of the voltage rating on the motor? is that the voltage as which it will run continuously for infinite time? I'm expecting that I'll be building my own controller for it. When i crack it open, i'll look into the cost of adding an additional battery to bump it up to 36 volts or something... then maybe 3 more batteries to parallel with it so i can run to the hardware store with a backpack
