Old 03-07-2009, 12:24 AM   #22 (permalink)
8307c4
beamer - '91 bmw 318is
90 day: 32 mpg (US)
Originally Posted by Southcross View Post
actually.. older cars with low compression engines don't have knock sensors so no, the ECU if it has one, won't do squat to the timing. I know I can retard the timing to help prevent ping, but that kind of counteracts the reason for increasing the compression.
I can actually get some pretty significant increases in compression... the head gasket I'm having made will increase the engine compression over .7 pts (from 8.2 to 8.9:1). I could theoretically go as high as 9.1:1, but I fear excessive mechanical interference if I were to do so.
Well if it doesn't have an ECU and it is carbureted then your car would benefit
from running premium anyhow, why go through all this trouble and expense
when a simple price increase at the pump would yield at least as much?
