Wow, you guys are going hardcore on this...
Piwoslaw - Just use normal adjustable airshocks that will fit in your vehicle. Someone somewhere will be able to cross reference them for you.
I used to have adjustable air-struts on my first Honda (not for Fe reasons) and I just kept a 20lb CO2 tank in the trunk, the struts were hooked up to valve blocks with schrader valves in them.
