Would it? Or would it keep the tire at the car manufacturer's specified pressure, which as we all should know is set 10-20 psi too low in order to give the squishy ride feel that they believe is "comfortable"?
No, the owner/driver sets/adjusts the pressure; it comes in manual or electronic versions. If you go with the electronic version I don't see why you shouldn't be able to change the pressure while in motion. In fact it says so in the PDF.
And as for increasing the cost of the tire? They are testing two systems; one fitted in the tire and one in the rim.
