Old 03-07-2009, 06:35 PM   #11 (permalink)
ConnClark
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
Originally Posted by tasdrouille View Post
Do you have anything to back this statement? How much do you think 100 F higher IAT raises the combustion temperature? Were you talking about just the warm up phase?
100 degree higher intake temps will raise combustion temps quite a bit. For the same amount of power out your cylinders have less air and egr to heat. It therefore heats it even more. Your putting the same energy into less mass that has already been heated 100 degrees. You'll probably end up with combustion temps 250 to 350 higher than normal when all is said and done.
