Old 03-07-2009, 08:19 PM   #39 (permalink)
roflwaffle
roflwaffle's Avatar
Camryaro - '92 Toyota Camry LE V6
90 day: 31.12 mpg (US)
Red - '00 Honda Insight
Prius - '05 Toyota Prius
3 - '18 Tesla Model 3
90 day: 152.47 mpg (US)
Are you attaching the sprocket to the axle hub or shaft? I've been thinking about doing this for a couple years too but the shift linkage is in the way on one side and while the other side is doable if I went to manual brakes, something I was planning on doing anyway, it's right next to the exhaust manifold which probably would require a heat shield and funky electric motor mount. My pickup would be easier since I could just shorten the driveshaft and put a double shaft motor inline, but since it has to be smogged I have to get it legal somehow and the PR person I talked to at CARB was a total bonehead.
