Originally Posted by my first gmc
How about lowering the car static, then putting helper bags to raise the car when needed. Far less expensive and simpler to setup. Because you would only need one fill and one dump for all four air bags or shocks. imo
That's probably the best way to go. Lower the car in such a way that the geometry and everything is cool, then jack it up only at low speeds, so handling won't be much of an issue.
Thanx everyone for the advice
- Adam
What matters is
where you're going, not
how fast.
