Engineering first
Originally Posted by roflwaffle
No, you didn't misread the charts. However it appears you didn't understand what I was talking about. Specifically, you stated that the Atkinson cycle results in a substantial reduction in throttling losses in low power regions, however when comparing it to older engines the change in BSFC compared to load, adjusted for displacement/age of course, is more or less identical. In other words, the Atkinson cycle didn't do a lick for low load throttling losses as far as I can see, adjusted for the difference in overall efficiency/displacement. Granted, Toyota has increased overall engine efficiency, just like they did when comparing the two sixes made about a decade apart in the BSFC map, but all the Atkinson cycle does is allow for a cheap way to reduce the effective displacement, aka a cheaper way of destroking the engine.
Then we'll have to agree to disagree. I can't ignore my data:
I was hoping the Autospeed article on EGR might have also given a clue.
In engines that use throttles, high pumping losses occur in part-throttle conditions. That is, the engine needs to do work in order to draw air past the partly closed throttle. One result of this is that as load decreases and the throttle is closed to a greater extent, Specific Fuel Consumption (ie the fuel consumed per power produced) becomes increasingly worse. . . .
Because half of the intake charge is pushed back into the manifold for the next cylinder taking in its charge, the throttle plate pumping losses have been effectively cut in half. Still, the results are quite telling on the road.
Well, lesse, the old transmission over the same speed range would see BSFC increase about 9% compared to the minimum, specifically a minimum of 237g/kWh and a maximum of 260g/kWh, and the Prius also exhibits a ~9% difference with a minimum of 230g/kWh and a maximum of 245g/kWh. The biggest difference is the more "open" ovals as engine speed increases, which is due to the offset crank and lower friction losses, not the greater expansion ratio AFAIK. Course, like everything either one of us, or possibly both of us, could be wrong, so in short we need more info IMO.
A closer comparison would probably be the 2NZ-FE, although I haven't seen a BSFC map for it, and for that matter, since we don't know what the effective displacement of the 1NZ-FXE is, who knows what Otto cycle engine it would be equivalent to in terms of displacement. If we could slap something together with the same effective displacement, offset crank, all that jazz, less the greater expansion ratio of the 1NZ-FXE, then we could see what the difference is. Until then, all we can do is (fun IMO) internetz speculation.
Just pointing out there are a bunch of 1NZ-FE engines around. Feel free to find a BSFC chart for them. However, the 2NZ-FE engines are an entirely different breed.
. . . I've never heard of a greater expansion ratio increasing stress outside of conventional engines. For those it's a given since the CR has to go up too, but if possible, it seems that having ER>CR would lower stress on the engine internals all things being equal.
The 1NZ-FE engine was more likely developed for the Otto cycle engines. The hybrid version is a simple modification of an existing Otto engine and that is probably what set the maximum expansion ratio. After all, it takes a pretty high octane fuel to run without knock at 13 to 1.
. . . All things being equal, an engine with a lower CR should see less stress on the internals, and by increasing the expansion ratio they're lowering EGTs/extracting more work over a greater time period, which should also decrease stress compared to extracting more work over the same time period. If anything I think the expansion ratio was dictated by what Toyota could do with the combustion chambers as opposed to the mechanical limits of the block.
Same answer, different path, no problem.
Bob Wilson
2019 Tesla Model 3 Std. Range Plus - 215 mi EV
2017 BMW i3-REx - 106 mi EV, 88 mi mid-grade
Retired engineer, Huntsville, AL
