Old 03-08-2009, 09:13 PM   #22 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Piwoslaw - Get an alignment done for the height that you plan on spending most of your driving time, obviously.
Also - keep in mind that when you "jack up" your suspension, you just might go higher than your springs extend, which will unseat them. This can cause serious problems. This would normally happen only if you have coilover springs, which have been shortened to accommodate the vehicle being lowered, or in any case where the springs don't actually get fastened to both perches.
Also keep in mind that lowering your car isn't really getting rid of that much frontal area, either. The only thing you're really getting rid of are the front/exposed areas of the tires that you're now covering, and any suspension components that might get hidden in the wheel wells or behind something.
The real benefit comes from less air being able to make it under the car, but there are much cheaper/easier ways to accomplish this as well. See: belly pans/Air dams.
They don't necessarily stop the air from getting under there, but if you can clean up the flow, who cares how much gets under it?
Aesthetically, it might look like you've accomplished something major, but MPG-wise, I don't think you'll be satisfied with the result of all your work.
