Old 03-08-2009, 10:43 PM   #24 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
1. Try something with airless tires and get back to us.
2. There are still many elements flexing in the Tweel so I wouldn't think it prudent to speculate on r.r. vs. conventional.
3. Why would adding a sidewall kill the r.r. part? It could be made much thinner/more pliant than a load supporting sidewall.
6. It is tough to come up with materials/structures that weigh less than air.
Most things that have airless tires also have solid tires, and no suspension.
This (in car form) isn't even close to that.
Forklift tires, are press-fit to steel donuts. They're vulcanized rubber sheets themselves, wrapped around a steel drum, then press/heat formed.
large equipment airless tires are generally about the same, except often with split rims instead of press-fit rims. They also have no give, other than the 70D rubber's propensity to "squish" slightly.
The Tweel is a whole different ballgame, in that it actually DOES flex, quite significantly. Yes, the ride is harder, but I cant imagine it being much harder than the ride on a set of 215/35ZR18 tires with 60PSI in them on a car that only weighs 1600lbs, and I don't really consider that harsh either.
As far as RR goes, maybe I could be incorrect about having a guaranteed better RR, but intuitively, it should. I say this b/c even though there are more flexing components, the flexion is all at a 90* angle to the direction of motion, or "radial flexion". Compared to a standard tires which has flexion in every direction on all 3 axes.
