Originally Posted by Deezler
Cd of 0.45? That seems a bit on the high side; I used 0.35 in my calculations but suspected it was a little optimistic. Do you have a source? I couldn't find any data on this.
Mayfield has a similar year Quantum (wagon) at .4, and those are longer/more streamlined than the short/fat box that is a bunny, so .45 seems reasonable.
Owners report .4-.48, with .42 and .48 supposedly being from published books.
As for weight, this site lists 1775 lbs dry. Perhaps not the best source.
That sounds like the dry weight for a early bunny.
Car and Driver has an 83 GTI at 2100lbs wet. Toss in a 150lb driver and we're at ~2250lbs, and the extra 50-100lbs from the TDI and associated will probably put it over 2300lbs, depending on where they start of course. Add ~25-50lbs for a four door, maybe drop some w/o AC, etc... It really depends, but IME they'll probably end up around ~2300lbs w/ driver unless they do some weight reduction.
Should be considerably less than 2300 lbs even with a driver and fuel. I would expect these guys to rip out most of the interior anyway.
They could, but I don't think there would be room in their budget. They could tear everything out, but in that case it wouldn't be very bearable. Trust me on that one.
Anyway, I listed all my #'s used, you can see from my plot that this site is calculating just 13.7 HP to maintain 60 mph, with all losses factored in.
I've done the same, with sources. Since I've owned a couple I've been up and down the interwebs, and a TDI in a stock VW with a ~150lb driver should come in at ~2300lbs, plus the horrible drag coefficient, will need ~18-20hp at the flywheel, depending on how efficient the driveline is, something I actually haven't seen any figures on.
