I'm envious of your heaters. I regret not installing one this winter.
Got new side skirts figured out. Dad has the "hook up" at his old work. So he can get aluminum pieces cut on a water jet. Then (try) epoxy or similar resin to attach apprx 5 brackets to screw aluminum skirts into.
Should I make aluminum bigger so its flush with outside of car. Or have it actual size so it sits inside of wheel well?
I'll probably have aluminum cut for grill block too!
Btw. Your car has been around a bit more mileage wise than mine. But do you have any rust forming on the bottom of the wheel wells towards the front of the car?
