Old 03-10-2009, 03:20 PM   #22 (permalink)
shovel
So.. cut a slot in your hood and "plumb" the air that passed through your radiator, smoothly - up into the air stream over top of your car. Then put a full pan under yer belly since you no longer have to dump engine heat down there, and you won't have to worry about the aero of your engine bay 'cause it will be isolated, right?
