Old 03-10-2009, 03:43 PM   #23 (permalink)
winkosmosis
Originally Posted by shovel View Post
So.. cut a slot in your hood and "plumb" the air that passed through your radiator, smoothly - up into the air stream over top of your car. Then put a full pan under yer belly since you no longer have to dump engine heat down there, and you won't have to worry about the aero of your engine bay 'cause it will be isolated, right?
Discussion of hood vents
http://ecomodder.com/forum/showthrea...vent-6543.html
I have no idea if the top vents would be good or bad for aerodynamics. I read somewhere yesterday that race cars reduce drag by using the top of the hood for air outlets, but I'm not sure if that is true.
