Hey, how much did you pay for that lexan for the grill block?
Quick mock up of template for skirts.
I have it scaled in photoshop, so I can draw up a template with the cad cutter.
This is the "slightly" bigger than wheel well mock up. Do you think that will be able to bend flush with the car? Or should I go less? Don't forget back of wheel well has a curve so it'd be impossible to put it there. I think this way will work better, because I won't have to curve aluminum nearly as much to avoid wheel rubbing.
![](http://imgur.com/JPSD.jpg)
