So I crunched a few numbers:
A 2 kw-hr pack will get you about 9 miles.
I'm finding the spreadsheet doesn't like such a small battery pack. It's because it also matches up battery output with what is required to reach certain speeds. So I lowered the output requirements significantly without adjusting the capacity, but what it means for you is you need to make sure have a high enough discharge rate to get your vehicle up to a usable speed. Without a high enough rate you will not be able to go all electric.
http://benw385.vox.com/
'Blog' on the open source electric motorcycle project.
Please come visit and comment!
