Thanks a lot for that info. You think double pack voltage could double the speed, eh? I'm thinking that on a motorcycle i wouldn't be able to go as fast as your bicycle with the same power. I'm thinking that a motorcycle is done best with either 2 hub motors or a larger motor inside the frame with a chain. I'd prefer the two hub motors, but then things get complicated.
What is the wattage rating of your motor and controller?
