Why not purchase a timer for your water heater? I installed one for my heater recently and boy 1 month later and there is a big difference in my electricity usage.
Also, if you live alone, shut the breaker off all day every day, flip it on 30 minutes before you shower and shut it off after you are done.
Trust me I just replaced my water heater and it literally took 20 minutes from fill time to hot water, those suckers heat water fast.
Also if you are concerned about water leakage, shut the valve off too at the water heater, it has to be there at the cold water inlet.
Good luck.
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
