Since I'm not going to be adding any fairings to this bike, I've repurposed the spots on the tank where they would have attached. The right side will have the keyswitch.
And the left will be a status indicator for the charger (LEDs and lens to be added later). I made it out of aluminum using the lathe.
The battery back is now bolted to the frame. I also have a plan for the headlight/front fender combination.
