Old 03-14-2009, 03:36 PM   #14 (permalink)
NeilBlanchard
Hi,
I think the best solution (as suggested in the Instructable) is to video the process, and then watch the video and stop it every 10 seconds, and record the speed. This is another area where the SGII will be quite helpful -- if you video tape it with speed and TPS (or RPM) on 2 of the displays, you can easily see what is going on.
I was wondering why the Instructable has the test start at only 70kph -- this would seem to barely be in the critical aero range? Also, are you supposed to coast to a stop, or just down below a certain speed?
