I'm running 50 psi on all four corners of the xD, brand new tires too ...
I didn't realize the sidewall stated max psi as 51. (Use to seeing 44psi)
Also dam dealer had the tires filled to 28psi, no wonder they try and scam you into tires for life with them ...
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
